Hello,
Does the order of applying an action to a page/item affects the behaviour of the actions in anyway?
Thanks, Lode
Hello,
Thanks, Lode
It shouldn’t, although there are some Actions that just don’t get along with one another, they are thankfully few. Are you having an issue?
On Jan 21, 2012, at 12:25 PM, Lode Rosel wrote:
Hello,
Thanks, Lode
Hi Walter,
Working on my “vet” site, I was trying out different things to avoid “nesting” SNW. When I added a “carrousel button” on the SNW target page, this button kept reopen that window instead of starting the action. There is also a “Show/Hide action” on that page.
So I started with a new FW file to test things out, and there al worked as it should. So I thought applying a different order was the reason for this.
Is there an overview of actions that don’t work well together?
Thxs, Lode
