Hi - Anybody had luck using the Apycom jQuery Menus? I just bough it (cyber sale) did what the text said but no joy heres my pitiful result note the missing menu top right!
Step 5: Change the items’ caption, specify links and change the menu structure as you
like. You can create as many sub-menus and list items as necessary.
Note: Please don’t forget to use the DOCTYPE declaration for universal compatibility,
for example:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
You have two items with an ID of “menu”, which is confusing the script. Change the ID of the item in Freeway (the Title field is used as the ID) to something other than menu and it should start working.
Cheers,
On 1 Dec 2011, at 19:20, Justin Easthall wrote:
How to add the menu to your own pages
Step 1: Select the style of the menu you like and download zip file with all menu files.
Step 2: Copy ‘images’ folder, menu.css, menu.js and jquery.js files to the same directory
as the page itself.
Step 3: Open your index.html file in any text editor. Copy and insert the following code
into the section of your page:
Step 4: Create an unordered list for your base navigation. Add the sample markup to the
for example:
