[Pro] Asian Text Appearing
Two odd things:
I have a folder, which is empty, in my Actions folder, which is named in some kind of Asian text. Any idea what it would be? I’ve just taken it out to see if it makes a difference.
Also, in the tabs example in the EWA templates, some of the components have Asian text names.
Weird…
Bob
Hi Bob,
I’m not sure what this is although if the folder starts with an underscore then it is likely to be an action that has created this temp directory. If you notice the folder again send me a screen shot and I’ll look into it further for you.
Easy Web Animator is produced by a Japanese company - Cyberfront - and a couple of the bundled English templates still have a couple of Japanese labels. These can be easily changed to whatever value you like without it upsetting the documents.
Tim Plumb
Creative Director
Softpress Systems
Follow us on Twitter: http://www.softpress.com/tny/064
Join us on Facebook: http://www.softpress.com/tny/063
Looking for a webhost? We love these guys: http://www.softpress.com/tny/sxf
Ah, OK. No problem.
Not sure about the folder in my Actions folder. This has been there for a while, but I was afraid to touch it!
I can’t imagine what action that would have come with.Plus, there’s nothing in the folder. It’s just an Asian language-named folder.
Bob
