[Pro] Background repels text
I’ve used the gradient from the Ambient theme. This starts at the top and drops down my page about 2 cms and runs behind a white HTML box. In this box, I have dropped a few HTML boxes for the page title and body text.
When I preview the page, it’s all shifted down and the text is not on the white HTML box. When I remove the gradient It’s all ok.
What I’m I doing wrong?
It’s a white graphic item not an HTML item… is that the problem?
Can you post a screenshot from Freeway showing how it looks in design
view, and another how it looks in Preview? If both elements are
layers, then it should just work – no difference between graphic and
HTML boxes at that level. Are you using the RPL Action in 5.5 by any
chance?
No, not using that Action.
Can’t upload the site at the moment so I can’t show you, but it’s still doing it.
A gap of about 1cm grows to 2 when I preview.
I’ve removed the CSS menu and this problem stops. Could it be that?
It’s certainly possible but it’s almost impossible to tell without seeing what your file or site look like. The best thing to do would be to get in touch with support, they will probably ask for your file, then they can let you know exactly what’s up.
