Is any part of your Carousel inline (nested inside another element from a text cursor)? You can use Carousel in an inline layout, but you have to follow a work-around.
On Dec 5, 2012, at 1:56 PM, rakeljuice wrote:
ok, my freeway is 5.5 and I downloaded and reinstalled the action. Althougt the action Protacolus it say is of August, when you download it the file says that is for 30 April, like the other I had.
Well, close, reinstalled and make a new blank site. Try carousel, and it works.
Go bak to my site, delete the page and make a new one, and when I export it says the same. The same line marked in red as at
And what I do is make a html item, inside it draw three grafic item to import three images, and the I cut and paste them again inside the html item with the cursor flashing to get them well aligned.
Hello Again. Something is happening… now, in the blank new site, I delete all the carousel, close, open, and when i try to make it again, the error cames. And I dont have vertical laignment or fullscreen at all.
Hello again. I ve done all the process again. 1. carousel, 2. vertical alignment, 3. background cover, 4. paste this script after Body for the full screen
and when I make the 4, the carousel stops. Ihave get to upload this to http://www.i-tek.es/demo/screen/ for be seen before the crash. So I think the problem is in the fullscreen method.
Any idea to fix it?
The code i pasted is:
<script src="http://ajax.googleapis.com/ajax/libs/jquery/1.7/jquery.min.js"></script>
<script src="http://www.teatrodelazarzuela.tv/code/screenfull.js"></script>
<script>
$(function() {
$('#supported').text('Supported/allowed: ' + !!screenfull.enabled);
if (!screenfull.enabled) {
return false;
$('#request').click(function() {
screenfull.request($('#container')[0]);
// Does not require jQuery, can be used like this too:
// screenfull.request( document.getElementById('container') );
$('#exit').click(function() {
screenfull.exit();
screenfull.onchange = function(e) {
var elem = screenfull.element;
$('#status').text('Is fullscreen: ' + screenfull.isFullscreen);
if (elem) {
$('#element').text('Element: ' + elem.localName + (elem.id ? '#' + elem.id : ''));
if (!screenfull.isFullscreen) {
$('#external-iframe').remove();
document.body.style.overflow = 'auto';
// Trigger the onchange() to set the initial values
screenfull.onchange();
</script>
The code you pasted includes jQuery. That’s not compatible with Carousel no matter how you attach it.
Draw a box on the page – graphic or html – and fill it with color so you can see it. Make a note of the name of this box, as reported in the Title field of the Inspector. Then back in the script base.js, modify the event handler assigned to view-fullscreen so it responds to your button’s ID. If it was item4 (Freeway loves to name things that way) then you would substitute item4 for view-fullscreen in the base.js script. Upload the script again, and try it. Remember that this is case-sensitive.
On Dec 5, 2012, at 4:12 PM, rakeljuice wrote:
ok, good thing. It works, but not with my button. I ve pasted
Fullscreen
Cancel fullscreen
as well before body, to use robnyman buttons and it works, but not with mine.
So, how is the correct way to tell freeway what are the buttons I want to use?
Hello. This is what I did, and Ive done it again from zero, and it doesnt work. Now I have a cyan html box titled bigscreen, an din the base.js I substitute view-fullscreen for bigscreen, and nothing happens. I used this method to identify buttons with the JQuery one and it worked. What I am doing wrong now?
thanks. The button id is now bigScreen, and in the base.js the code refers to this id, that is for testing the cyan square, but I need to be the graphic others.
base.js
and in my file, after body
<script>
document.addEventListener("keydown", function (evt) {
console.log("keydown. You pressed the " + evt.keyCode + " key")
}, false);
</script>
<script src="js/base.js"></script>
The script you quote below might be what you think is on your server, but in fact it reads var viewFullScreen = document.getElementById("ocupando"); where you think it reads var viewFullScreen = document.getElementById("bigScreen");
Make sure you have uploaded the most recent version of your code to your server, and this might just work.
base.js
<script>
}, false);
</script>
Im testing all the time so, I have changed the name just for a while, and it seems that you just entered on this while. it reads bigScreen. Let me upload the files again, please
And the thing is that I need to do that manually, exporting and editing the html. I think there wolud be another way to do that directly from freeway. My site has lots of pages. If I need to edit them one by one, Ill never finish…
