ah, and the freeway site is uploaded now withou the edit changes I told you, just to let you see the real situation.
Here is one I have done using that script.
http://www.deltadesign.co/examples/carouseltest.html
I used the original base.js referenced before end body
The 2 buttons are just buttons with the IDs of view-fullscreen and cancel-fullscreen.
And I have removed the reference to the keydown listener.
Yes, but I need my graphical buttons. With the fabric button it works, but not with mine. I need to convert my buttons in the working ones. I hoper I made me understood.
in your file, you have added this line to the div so, your div works as a button. How can I do that to my buttons?
You don’t need the button tag to do this. Any element can respond to a click. Seriously. An image, a DIV, even the page itself. Give me a moment and I’ll show you what I mean.
ok, thanks, because Im completely desperate. If you dont mind, I compressed my test file. Its at http://www.i-tek.es/demo/screen.zip, and then its more easy for you to tell me what to do.
Thanks a lot
Visit my example again
ok, Thats it, but how? If I just put the correct ID it the item properties palette it doesnt work
http://www.deltadesign.co/downloads/button-archive.zip
Just watch when you copy/paste these over as FW will not allow 2 different items to have the same ID and will rename them.
Please start over with the following example. Follow these steps exactly, don’t do anything that isn’t in them. Start with a completely blank page.
Line by line, here’s what the code does:
This code will be completely unobtrusive and will not interact badly with any other Prototype/Scriptaculous code on the same page. Continuing from this example, you can layer on other (non jQuery) effects and continue until you have a working example of your super-size page.
your buttons are different from mine, because mine are pass trought and in item palette they dont appears like combine with children, but I have pasted your buttons, changing the ID and doesnt work.
ok, waltd Im doing that. Give me a while
ok, it works, and with my button. Thanks.
Then, Dont I need the .js script at server?
And, how shall I code for the exit full screen button?
Left out one critical instruction: You must have the CSS Layout button ON before you start drawing anything. That’s the key to getting elements on the page that have ID attributes, which this code relies upon. You seem to have been doing that, but I’m adding this note for posterity.
yes, and it works at my online example http://www.i-tek.es/demo/screen,. Have two questions:
You would add a second block of code in the same Function Body:
If you really wanted to get tricky, I can think of a way to make the same button do both things, but for this example, make two different buttons with the IDs ‘bigger’ and ‘smaller’.
No, you don’t need that external script if you use this approach. This code could be put in an external script file if you like to work that way, but you would need to wrap it in the same function that the Protaculous Action is adding around it: the unobtrusive DOM ready listener:
document.observe('dom:loaded', function(){
//your code here
Okay, with a single HTML box as your trigger, containing a single paragraph of text that reads “Show Full Screen”, and with the ID toggleScreen, you would use this code:
You have to be careful in Freeway to make sure that you don’t end up with any tags in the resulting HTML box; these can arise when you use the Inspector to style text instead of the Styles palette and a manually-constructed paragraph style. If you do, then this script will replace them after the first click, and your text in the button will become un-styled Times Roman in black by default.
Thanks for the explanation.
The second block of code doesnt work. The example is online.
I thing using two buttons would be ok, but now, I need to finished this…
Waltd, thanks but I need this button, no a text paragraph…
