[Pro] Background Supersizer and PHP
Hi everyone,
really love the background supersizer action but is it possible to use the slideshow function with Webyep?
In order to alter a page with Webyep I have to change page extension to .php. BG supersizer slideshow works great on a .html page but refuses to ‘slide’ on .php page.
any options?
regards,
Marcel
This is a Page with a Webyep element on and the Background Super sizer works fine.
http://www.bnh-photography.com
The transition is Fade but I had it on Slide and that worked too. So the answer is yes you can.
Richard
Don’t know what I’m doing wrong then.
test 1:
page-extension is php bg supersizer set to slideshow/fade
http://www.campsconstructie.nl/test.php
(every refresh it shows another background from the selcted image folder)
test 2:
same page but page-extension set to html and removed the Webyep pageaction
works fine now
http://www.campsconstructie.nl/test2.html
It could be a webyep/protaculous/lightbox clash. Now don’t take my word for this as I am not that knowledgable with code but you might turn off the webyep references and to do this you will need to add two lines of code within the config-inc.php file which can be found within the webyep-system folder.
Take a look here for more details - http://www.freewaytalk.net/thread/view/96137#m_96137
Note the Caveats - although2- the log-on/carousel combo seems to be no longer an issue.
Richard
nope, doesn’t work. Also tried to delete the Webyep login button.
I removed ‘fancybox’ from the opt folder…now it works.
thanks for you replies
In that case I would contact Max of Webyep and/or Walter of Protaculous - they will be able to offer an explanation.
R
