Is there any image quality control settings with background images in Freeway Pro?
I am importing a vector .ai file but it seems to be alot lower resolution than other .ai images (which I can control the quality of in the inspector panel) in the site when published.
Hi Danny, I’ve had this problem before with vector files (not specifically with bg images though - I didn’t know you could use a vector file for a bg image). I’ve ended up rasterizing them in Photoshop and exporting in a web ready format.
I think when something is used as a background image, it’s pass-through, meaning no resizing or resampling takes place within Freeway, so get it to your correct format before importing.
On 5 Feb 2013, at 11:48, Danny wrote:
Hi
In that case, only Mac users (who have QuickTime deeply embedded in their browsers) can even see this image format at all. I have been so spoiled in the past by Safari that I have published a site with TIFF images in it, much to my clients’ horror…
