Happy Thanksgiving all
my question is this
is it possible to have a 100% banner (width of browser) without having to set page alignment to None. This creates a problem with the rest of the pages being set to none, as far as centering. I do know how to create the inline containers for the body elements, but this method does not work on some things.
My method was to make the banner very wide so that no matter what size one opens site. It holds well but on a mobile device, page bears left. I dont hold too much weight on the mobile viewing - just want to make sure I am doing the correct thing with this
Thx for advise…
I have done a test site with pages set to none. Its difficult when it comes to product pages. I just wonder if I do it this way by forceing the stretch with browser is ok
thx http://www.carlagrande.com/test2.html
Hi Dave
yes you mean inspector 2nd tab and import the image set to top and tile… yes I have done this in my first round but its too wide. I need it to be a narrower banner. This way takes up too much of page, although much easier. Is there a way to make height dimension shorter?
thx Dave
C
