I’ve used <base href="/" /> on particular pages in a site, in conjunction with a CMS which is creating some awkward URL’s to tidy up using .htaccess and maintaining the resources keep pointing to the page in the top level folder.
I have written just such an awkward CMS at least three times, so I know the problem you are facing here. No, there is no downside to this fix that I know of. The right fix would be to have the CMS’s “friendly URL” redirect be written better (can’t say as I have ever worked out how to do that myself, just started using Rails 8 years ago and never looked back). Freeway’s relative URLs are absolutely correct and proper, and work 100% of the time, unless the CMS assumes there is no relation between the filesystem and the URL.
Thanks. I’ve been struggling finding a way of fixing these URL’s for ages when I stubbled across this fix. Couldn’t believe it was so easy and must be a downside somewhere.
I’m using the basic Perch CMS. I believe Perch Runway handles routing a whole lot better as the pages you create are held in the CMS rather than Perch Basic where you’re simply inserting the CMS into static pages.
