I know this is probably considered quite standard, but after a certain point the distinctive page links on scramblestuff.com collapse into a simple menu button.
whenever I try to edit menu fields within the ‘Phone (320)’ tab, the elements are manipulated in the ‘Tablet’ and ‘Default’ pages as well.
How can I edit and delete elements without affecting the other pages?
Jack
That’s easy, there’s this option on the action-palette > css menus action where you can select one of your breakpoints where you want the mobile menu to take affect.
– Richard
