Hi,
I’ve built a site using the BAM action beta and CSS menu actions, example as per link. It’s OK, but the formatting plays up in different browsers and I’m not all that happy with it.
I’m thinking of just binning it (after MANY hours of trying to get it to work) and replacing it with something much simpler. I seems like I’ve over complicated things.
I was considering trying to build it out of rollovers and slaves instead. Can anyone suggest another way, or think this is the right way to go?
Thanks for your help.
Neil.
http://connectcreative.co.uk/mindful.html
