[Pro] blog link
I am having problems linking my blog to my website.
I have an account at blogger and have successfully copied the html code etc and can see the new
templates style on blogger.
See http://mytestproof.blogspot.co.uk
I have gone over my freeway document and double-checked that the external hyperlinks for the blog are still there.
I find that at first the links hold. i.e. from the Home Page (Welcome) I can enter the blog. And I can read it.
But when I move around the site, the access changes, and I get the latin gibberish instead.
And from the home page I can no longer access the blog.
When I try to upload my changes, the old site seems to persist.
http://testproof.uk
My guess is that you accidentally linked to the internal page that you used to create the blog template code, instead of linking to the actual blog URL (http://mytestproof.blogspot.co.uk). The latin gibberish is only on that internal page. Although it sounds like you already checked the links, I’d recommend double-checking them.
Also, the blog link in the header is pointing to #nil, so that link must be malformed too.
