Mayday, mayday! I created a simple Blogger template using the Freeway actions back in December that worked perfectly. The client asked me to change a font in the header background (used as a PNG) and some of the menu text, but when I try to upload the template to Blogger I get a “bx” error with varying codes.
This is the site (http://www.bluewaterhomebuilders.com), although I haven’t uploaded the changes and now the blog header graphic appears to be missing. Any suggestions?
Google seem to be having some problems with their new interface. We noticed a problem a couple of weeks ago that seemed to get fixed, but perhaps not.
If you’re using the new interface, can you try using the old one by clicking the link at the top right of the page, please?
Let us know if you’re still having problems.
Joe- perfect! Blogger put up a message that said the template was missing some widgets, which in turn prevented some of the graphics from appearing, but once I deleted the widgets it was fine. Thanks for the help!
