Caleb_G
(Caleb G)
March 15, 2012, 5:10pm
#1
Talkers,
I’m having a problem with my blogger template with the blog posts overflowing the box that I have set up for them. You can see it at: http://anson-s.blogspot.com/ (it’s all Lorem Ipsum right now).
If you are so inclined, you can download the freeway file from here: http://dl.dropbox.com/u/55769872/Anson%20S%20Blog.zip
Am I doing something wrong, or do I just need to keep the blog posts shorter than the box that I sketch in?
Hi Caleb,
try this:
http://dl.dropbox.com/u/8231701/Anson%20S%20Blog%202.zip
Huhh - never used dropbox - pretty cool, should keep it in mind.
Hope this helps you out.
Caleb_G
(Caleb G)
March 15, 2012, 8:55pm
#3
Sweet! Thanks Thomas!
Caleb_G
(Caleb G)
March 15, 2012, 8:57pm
#4
Now I have to ask, how did you do it?
the key is to build a little “inline stuff”. I wrapped your content and footer into a content-wrapper div.
I btw forgot a little thing you should do now:
Activate the element view in the sidebar. Choose the content box, go inspector first tab and set it clear both. Repeat this step for the footer. I forgot this to do.
I once wrapped this in a small screencast so in a silent minute have a look at:
http://kimmich-dm.de/screencasts/screen2-inline.php
Nothing high rated but it should make clear the way I did.
PeterH
(PeterH)
March 18, 2012, 8:23am
#6
Thomas, thanks for the videos, please keep them up!
For your information I haven’t been able to get them to load in Safari? (Ok in Firefox)
(Sorry for the hijack of the thread)
Peter
Hmm - that’s true (never had an eye on).
I usually am on Chrome so I often do not double-check the other webkit one. Anyway I’m not really sure how to solve (very disappointing … )
Thanks for pointing
