I have CSS turned off, and have set the site output to XHTML transitional. When trying to create a blogger action, I get a message in the actions window which says the action can only be applied to XHTML pages. There is only one page, and it is XHTML. What is happening?
Each page in your site can have a different output mode, and the setting in the Document Setup only controls the pages you make AFTER you make that change – it does not alter the existing pages. If you want to change the existing pages, first try changing the output mode on the Master page that controls the page you are trying to change, then if that doesn’t work (because the child page has become detached from its master at the output settings level) then also try changing the page itself in the Output tab of the Inspector.
