I’ve been playing around with the Blogger actions and - I realise this is a bit of an old chestnut - can’t get the header image I have created to show in Blogger. Clearly, I have mismatched paths, but I can’t see where. Incidentally, the blog looks rubbish - don’t worry about that, I’m merely testing an old blog with the action to try and get the hang of it!
The link to the blog is above. The URL in the Freeway web address box, in the Upload window, is:
Did you upload your Blogger template to the same address that you entered as the Web Address in the Document Setup dialog? If you are uploading to a sub-folder, then you have to enter that entire path exactly.
I uploaded to a new folder on my server, which is the address I entered in the Upload window. The FW template sits in that folder, whilst the offending image sits in the Resources sub-folder.
It looks like you’re doing everything right though, so if you need to keep the redirect it might be worth uploading the blogger template page to a different address and putting that in the Web Address field.
On 13 Sep 2013, at 17:46, gavtro email@hidden wrote:
Thanks, Walter.
