gdlow
(Gordon Low)
January 5, 2011, 12:01pm
1
Hi there
Hope you all had a Happy New Year and a great Christmas.
I’m working on a new site and have decided to incorporate two pieces of code previously posted here to enhance the CSS menus.
This is the markup code I have inserted before /head
<style type="text/css">
.fwNavItem a {
-webkit-transition: all 0.5s;
-moz-transition: all 0.5s;
-o-transition: all 0.5s;
-ms-transition: all 0.5s;
.sub {
-webkit-box-shadow: #505050 3px 3px 16px;
-moz-box-shadow: #505050 3px 3px 16px;
ul.sub, ul.sub li.fwLastChild, ul.sub li.fwLastChild a {
-webkit-border-bottom-right-radius: 7px;
-webkit-border-bottom-left-radius: 7px;
-moz-border-radius-bottomright: 7px;
-moz-border-radius-bottomleft: 7px;
background: #303030;
</style>
You can see it working on the unfinished site at http://www.ltbuses.com/index2.php
However when I use the same code in the Blogger template it complains that:
Your template could not be parsed as it is not well-formed. Please make sure that all XML elements are closed properly.
XML error message: The string “–” is not permitted within comments.
I’d really appreciate it if someone could let me know how I should change this markup so Blogger will be happy with it.
Many thanks
Gordon
Joe2
(Joe)
January 5, 2011, 12:08pm
2
Hi Gordon,
try the following:
.fwNavItem a {
.sub {
</style>
gdlow
(Gordon Low)
January 5, 2011, 4:40pm
3
Hi Joe
Brilliant - all working perfectly, many thanks.
I know the code is easily edited but a “CSS Menu Extras” page action where you could change all the settings would be great if some action-eer was able to work their magic.
All the best
On 5 Jan 2011, at 12:08pm, Joe Billings wrote:
Hi Gordon,
try the following:
.fwNavItem a {
.sub {
</style>
