Hi there
This is most likely to be a case of user error but I am at a loss to work out why simply adding the “Blogger posts” actions causes my inline design to fall apart. I have tried as many different combinations and settings as I can but have yet to find a solution.
Here’s how the page should look (minus the blogger posts action):
http://cristaelb.com/blogger/test/without-action.html
And here’s what happens just by adding the blogger posts action:
http://cristaelb.com/blogger/test/with-action.html
As you will hopefully see in the second page everything that comes after the “full-width-body” is pushed outside the rounded corners and shadowed “body”.
I have even stripped the page back to basics with only the CSS menus and blogger actions applied and the same still happens:
http://cristaelb.com/blogger/test/stripped.html
if someone could spare the time to work out where I’ve gone wrong it would be much appreciated.
All the best
Gordon
