Have a client who edited the HTML in Blogger to update his template with the Freeway created actions. Had to use old Blogger interface as instructed. Everything updated correctly except several graphic images. Any ideas?
Not without a link.
Here you go: http://i-actblog.blogspot.com/
Here’s a link that show’s the masthead and background images. This is the part that’s missing from the blog.: http://www.i-act.org/iactmember/bloginfo.html
Looks like the Remote Resources action hasn’t been applied to the template page.
I say Remote Resources but I think that the blogger action reads the base reference to your Resources folder from the website address field in File Document Setup for your FW created blog page
Open the Document Setup dialog box and click on the Upload tab and under Web Address put the address of the location of your Resources folder.
ok, will try that. Thank you,
It is the typical FW behavior that makes of a image.gif an imageb.gif, while blogger code seeks for image.gif. I recommend to complete delete the content of your resources folder. Hit CMD-P to publish again and shoot it to your server. I would bet (a little bit of my cents) that this should fix it.
