Trying to make a Blogger template for my daughter. At the top is a piece of art (jpg), under it is the blogger title, posts, profile, and archive all created with the blogger actions. When previewed on Blogger, the only thing displayed is the jpg. Anyone know what I’m doing wrong?
Do you have the “Classic Templates” checked? I got your e-mail. If you have that checked, uncheck it. I’ve seen this to be the reason why a few blogger templates did not work.
If not what’s the address, so we can see what’s going on.
Thanks for the response, Dan.
Where do I find “Classic Templates?” And here 's the address: willstampforwine.blogspot.com.
Mike
Sorry, not on my browsers. Safarai or Firefox. I’m on Mac Leopard. I
even looked for the checkbox on a PC. I can’t find it.
On Mar 4, 2009, at 2:55 PM, Dan J wrote:
When you paste “the code” into the “Edit HTML” area, there should be
a checkbox near the entry box.
You need to make sure you are using the latest template “type”. To do
this go to your customize section and click on Custom Design, on this
mage there is a n Upgrade Your Template button. Click this and select
one of the templates. This will force your blog into using the most
recent template type. You can then go to Edit HTML and paste in your
template from Freeway.
Make sure you don’t click the Revert to Classic Template link because
you will have to go through the above steps again.
Hope it helps.
be a checkbox near the entry box.
Solution for blogger XML error messages after upload new templates:
Hi everyone, I found another solution for bloggers who upload those
wonderful new xml templates but always get random error messages from
Google like “BX-bliced” or like: “error 12xllldj”, and any other error
codes.
I know, I know, there is nothing more frustrating than finding “that”
damn cool template for your loved blog but at the attempt to upload it
to your HTML editor in Blogger, you get error messages that don’t tell
you what to do to fix them.
This solution applies to basically all xml templates that fail to
upload successfully to blogger/Blogspot 2.0 (the “new blogger”) and
give you error messages like this:
This image has been resized. Click this bar to view the full image.
The original image is sized 722x500 and is 69KB.
What to do:
Download the template you want to upload (usually XML)
Get the xml opened in a text file or in any of your editors.
“Ctrl + F” (make sure the xml is open and in the active window) and
in the search box type “Widget”
In every widget line it will display something like this : widget
blablabla “blablabla1”, replace that number for a any other one.
Example, if the widget says 1, erases it and place number 2 instead.
So you will have something like this now: Widget blablabla:
“blablabla2”.
Do this to all widgets you find in you xml code. That may take a
few minutes of your time if you really want THAT template working next
time you upload it to your HTML editor in blogger.
SAVE it
Go to Blogger/edit Layout/HTML
Upload your saved xml
Save it.
Done!
Enjoy it.
I have done this with a couple of XMl and all of them displayed
different error messages but after changing the widget numbers in the
xml, they all upload ok and are ready to be boosted. I am not quite
sure of what is causing the problem, as the lazy Google teams
responsible for Blogger haven’t taken their fat asses from their chair
to solve this very annoying issue (or haven’t come any closer to the
office chairs to do so…). You can tell by the horrible templates they
offer users, just to start with.
Hope this helps you to succeed and load that pretty template you have
found around.
Cheers from New Zealand
Czarlzk
What I did was this: I made sure I was working on the new template version. The from Freewar I placed the code “copied to clipboard” in a text editor. Then I changed all instances of widget “blablablabla1” to “blablablabla44”. The 44 was just a random number I picked. Then I copied the whole code, went to blogger edit html, and pasted it into the field. Amazingly it worked!!! I hope this helps someone.
There’s got to be an easier way.
On Mar 4, 2009, at 4:33 PM, Joe Billings wrote:
This is taken from an old post:
Hope it helps.
Sorry, not on my browsers. Safarai or Firefox. I’m on Mac Leopard. I even looked for the checkbox on a PC. I can’t find it.
When you paste “the code” into the “Edit HTML” area, there should be a checkbox near the entry box.
Thanks to Dan J and Joe Billings for helping solve this problem. I apologize for my poor spelling and extra long posts (I responded from email instead of logging on to this forum. Dan and Joe contributed BIG puzzle pieces to lead me to the solution.
