I can see you can use the Blogger Action built in to Freeway 5 to create a Blogger template based on your own website so that it integrates with your website. I get that but as I have never blogged before I have a question…
If I create a website for someone else and incorporate a blog in the site how do they then post to the blog?
Log in with username and pw in their browser
and type!
There are also other options - all within the browser.
regards
Brian
Steve Kirkham said recently:
Hi
Yeah I found your tutorial and very good it is too (in fact I bookmarked your tuts page
I get how to actually create the template - I suppose my worry was that if I created a blogger template for a clients website that they would need Freeway to add content but you are only really creating the template and they add their content through their Blogger account in the same they would if they were using a simple Blogger template.
Something you may also try, to bypass the need for the client to log in (although it is simple enough) is setup the email posting option for them whereby they simply send an email to a certain address with the body of the email as the actual post and the subject line at the post title and blogger automatically posts that. Might get a little more confusing if images are being added but I suspect you just attach them and blogger posts them…
