I attempted to create a template for blogspot using the Freeway Pro tools (version 5.4.1). When I pasted my code at blogspot, I received the following error message:
““Your template could not be parsed as it is not well-formed. Please make sure all XML elements are closed properly.
XML error message: The entity name must immediately follow the ‘&’ in the entity reference.””
Given that I’m depending on Freeway for turnkey code, I have no ability to decipher this problem. ![]()
Any help would be appreciated.
