OK…After some more playing around I’ve managed to get the gallery in and working properly however I’ve not been able to do it as an in-line item.
I’ve had to float it as a layerd item then move it into an HTML item…Is this the correct method? I thought I could just double click within an HTML item and go to Menu>Insert>Action Item>Exhibeo Import ??
I’ll leave the first gallery in the collapsed state for a while just incase someone takes a look at this thread so that they can see the issue and perhaps let me know.
It probably helps to mention that you are using the Backdraft layout system
and not a vanilla inflow layout. I think Caleb has several solutions for
how to use Exhibeo galleries in Backdraft, and that may be where your
solution lies.
I’ve read through all of Calebs help topics on using Exhibeo and followed the instructions exactly. I have contacted Caleb so hopefully he can shed some light on things. I do have the galleries working as I want them too so all is OK but I think the way I’ve done it isn’t necesseseraly the best way.
