billyk
October 7, 2015, 10:34pm
1
Can anyone tell me why Exhibeo is displaying like this. Also can the Initial thumbnail image in Bloxx new responsive (flexible)
Billy
http://www.smartytest.com/evfarm/evergreenfarmgallery.php
Exhibeo mailing list
Your files aren’t where they should be
Failed to load resource: the server responded with a status of 404 (Not Found)
http://www.smartytest.com/evfarm/Resources/loader.css Failed to load resource: the server responded with a status of 404 (Not Found)
http://www.smartytest.com/evfarm/Resources/bloxx-styles5.css Failed to load resource: the server responded with a status of 404 (Not Found)
http://www.smartytest.com/evfarm/Resources/bloxx-styles4.css Failed to load resource: the server responded with a
billyk
October 7, 2015, 10:51pm
3
I’m confused. Are you sure. Because I see them.
Billy
billyk
October 7, 2015, 10:54pm
4
Yeah they are there.
Click the links - 404 for me
billyk
October 8, 2015, 12:32am
6
I just took them down trying to see if re-install of the exhibeo file might fix the issue. Give me a moment and I will upload them
Billy
billyk
October 8, 2015, 12:38am
7
Billy
billyk
8
Ok they are up.
Billy
You still have missing files - how are you uploading?
Failed to load resource: the server responded with a status of 404 (Not Found) http://www.smartytest.com/evfarm/css/bloxx-styles.css
Failed to load resource: the server responded with a status of 404 (Not Found) http://www.smartytest.com/evfarm/css/loader.css
billyk
October 8, 2015, 1:36pm
10
Are you saying you can’t see any exhibit instances on this page?
Billy
I can see the 3 initial thumbs but when I click on one all I get is the thumb image on a new page.
The files are not where the page code says they should be and so the galleries are not displaying correctly.
billyk
October 8, 2015, 6:01pm
12
I don’t understand why that is. I created the files in Exhibeo, exported them to Freeway and used the action to add them to my page.
Have you ever had this issue.? Am I installing incorrectly?
Maybe there is a java conflict with more than one instance?
Billy
I am not familiar with your workflow or how/what you have done to use 3 Exhibeo galleries on 1 page.
Without more info including the names of all your files I am not sure what advice to offer.
All I can say is to go back over any/all instructions you were given/are following and make sure that you have done everything that was asked of you.
It may be that you have to rename files etc. and upload them outwith FW but it is not something that I have done.
billyk
October 8, 2015, 6:10pm
14
Ok
And do yourself a favour by starting on an otherwise blank page ie no flying Santa and no weather widget.
billyk
October 8, 2015, 9:11pm
16
Well I go the three galleries within one Exhibeo instance but as far as styling, I don’t know. Do I used floats,text aligns? I want them to be horizontal across the page.
Billy
Remember you have different screen sizes to consider too.
