I am – and was – an avid user of Freeway Pro: now with the update running on my first and second Mac – both having 10.9.4 – I am confronted with a curious bug; whenever I want to pull a new guide from the ruler (mouse left-click and pull) be it vertical or horizontal the whole application quits -
pretty annoying if you are into the third hour of your work and the 16th page…
I trashed the preferences file(s) to no avail – anyone experiencing the same?
If yes, any ideas how to get rid of this, or is this really a bug?
This has been discussed before (it’s always worth searching before starting a new thread). Also, a useful workaround is suggested near the bottom of the thread at http://freewaytalk.net/thread/view/150822
