Good evening… Delta Dave was kind enuf to give some advise on how to use Scripty LB3 to replicate the pop-up windows at the link above… I am rebuilding this site in FWP… However, whether I use SLB3 or Exhbio, I cannot get to the end state I had before, albeit popup instead of a lightbox !!! My cake is to be able to have a single image of the target item on the main page with a caption and then have a lightbox containing a large version of the image along with the rest of the information about each particular item… If you go the link, select any image and you will see an example of the output I desire… The icing would be to allow navigation to the remaining items after the iniitial selection… Any thoughts… Mark z
http://zscapes.com/zcyosemite.html
Exhibeo mailing list
