I’ve been trying to get the send form action on this site to work for sometime now and getting nowhere. My hosting server support keep telling me that the problem is with my php script. I have installed the latest php action for Freeway 6 Pro which the site is created in. Themeesage I keep getting when trying to send the contact form is:
Forbidden
You don’t have permission to access
/contactportraita-go.php on this server.
Additionally, a 404 Not Found error was
encountered while trying to use an ErrorDocument
to handle the request.
I have set the correct permission on the send form php file on the server to 644, but still nothing.
If anyone can help it would be greatly appreciated.
BTW - once you have done this test then take the asdfasdfsdfdfs.php file down as it can compromise your server’s security if someone/somehacker comes across it.
Thanks DeltaDave,
tried that and it gave the same error message as my contact form. I have deleted the test file from the server too. What would you suggest next?
1 and 1, and they have replies saying php is enabled in my package and that the problem is with my script. They have offered to call so may take them up on that.
Do you have access to your Apache (Web server) errors log? That might be instructive. The fact that it runs without errors on an unmodified PHP 5.4 (and 5.3) server, should also enter the discussion at some point.
Just had an email from 1 and 1 support apologising for misinformation and inconvenience as they have now noticed that my package is an old type that does not have php. I had previously asked if php was supported and was told yes. Looks like I have to upgrade to a new package. Thanks for your replies.
