I’m going through a bunch of temp styles in an old document trying to delete them all and replace with proper ones. Some of the temp styles are coming up with fonts that aren’t in the document (as far as I can see).
Does Freeway remember fonts that you’ve tried, then abandoned? That would be weird…
Is there a way to have Freeway find the temp styles so you can properly replace them without guessing?
Thanks…
Bob
