I hope my question makes sense.
However, I understood that overlapping graphics is the way to “combine” them so that they can interact. Like perfectly overlapping buttons in a rollover. So far so good.
Now say I’d like to add an interaction (make it visible for example) to a non overlapping item from an existing rollover button. How can I do that? Can I?
The checked combined graphics option in the inspector properties does not say much to me since I don’t know which other graphic it refers to. Can I select a non overlapping target graphic item?
Ever learning, even on weekends, tx for that!
Claude
Hi Claude
In the inspector you need to first check the ‘layer’ box. Click the item you’re working on, and on the left hand top option you’ll see the ‘layer’ checkbox, then you can move it up or down. Then do this with each item you’re working on in turn. The alternative is to click the CSS button on the menu till it becomes blue. There are pros and cons to this method which is for a whole different discussion!
Good luck with this - persevere & you WILL get there. As my great hero John Muir says ‘perseverance FURTHERS!’
all best wishes
Dick
On 12 Sep 2010, 12:29 pm, thetribe wrote:
Hi Claude
Tx Dick, but I am not sure to understand your answer. Are you sure to answer this thread and not “[Pro] Cannot modify hidden graphic item”?
Perseverance, in my case, is not an issue. Getting the substance -is- the issue. Tx again!
Claude
