I can’t seem to remove this unwanted space between my header wrapper and my body wrapper. I’ve removed the margins and padding from the top of the wrapper element, but all that does is (excuse me) jack up all the margins, but the space between the two remains.
I’ve attached a screen shot of what it looks like in FW (Screen Shot A) and what it renders in a browser (Screen shot B)
I’ve read about removing the p tags, but it seems like they are modifying code, and hmmmm…where to do that?
Is there a simple solution that one can recommend? If a simple solution isn’t available, I’ll take a complex one, but slowly, please.
I think you might be on the right track with “margins and padding” - but you might need to try it on both the header, body wrapper - AND possibly elements inside them as well (graphics or HTML boxes). Are you editing a template?
In the drop down menus for margin & padding you’ll see “custom” options where you can set L, R Top, Bottom to each have a different value if you like. You may need to edit the bottom of the upper object to have 0. and the top of the lower object to 0 as well to get them together. If one of these has a “-” value in the inspector, it may already be assigned a custom mix of values.
Hope that makes sense.
Screenshots are nice but not helpful. It says nothing and shows nothing. Try to wrap all this in a live-example and share us a link. Code says more than thousand words (or images).
