Hey Walter
the carousel action is having a problem
I did update the action. I checked an older site that I used the action on most of the site.
the images are not present. I did uncheck the Carousel and carousel pane on one of the items but nothing worked.
Please advise.
Which version of Carousel are you using? Softpress tuned up my original version (and posted it on ActionsForge) so it should work. Once you’ve upgraded, try it out on a new document with no other documents open. If you’re having trouble with an existing document after upgrading Carousel, you will probably have to go through these steps:
Remove the Carousel Actions from every element they have been applied to (tabs, buttons, panes, and main panes) on every page in the entire site. Leave the elements in place, and note any settings for each so you can restore them later. Make sure that the document you are working on is the only document open in Freeway.
Publish the entire site once. You don’t want to upload it, just publish it. This clears Freeway’s Actions cache, so you aren’t possibly using the version of the Action embedded in the current document when you try to re-apply the Actions.
Go back through the site and apply the Actions again, and pay attention to the version number shown in the bottom-right of the Actions palette when you do so. It should match the updated Actions.
That’s a lot of work, but it does give you a clean slate.
On Feb 1, 2013, at 10:21 AM, Carla wrote:
Hey Walter
Please advise.
ok Walt
I have an update , I just previewed that same site and now all panes are in view so thats good but all the containers ( borders are out of whack)
