I have noticed a strange interaction between the Read More and Carousel 2 actions. If you take a look at the link and select Read More on the news item about the New Clubhouse, it should display some text and three photos, more or less equally spaced out. However to get this spacing i had to make the Carousel 2 pane height equal or slightly greater than the actual article. Walter has previously indicated that all panes should be the same size. If i do make this pane the same size as the others the format of this article changes to the extent that some of the photos overlap each other and some of the text is not spaced correctly.
I haven’t ever tried to put anything other than a bit of text in a Read More container, so this is a first for me. Maybe try a different Action – use ScriptyLightbox3 to show a secondary page containing your “more” content. That way your carousel panes can all be a fixed size, and the fact that ReadMore alters the height attribute will not be an issue.
On Feb 21, 2013, at 5:52 PM, ejw wrote:
Walter,
Could you offer any insight into the issue i have reported please?
