You would apply this to the same page as the Carousel, along with the other Action(s) already applied. What happens if you host a page in HTTPS, but include some references to HTTP routes (script sources, in this case) is the browser, for very good security reasons, will just not load the HTTP sources. If the page is secure, then everything else in the page must also be secure.
On Sep 21, 2017, at 8:16 AM, Tony email@hidden wrote:
Hi Walter
Thank you for all your advice so far. The Above site has a SSL applied to it, however it has broken somne of the actions on the site.
• Forms, this has now been fixed as mentioned in a previous post.
• What is also not longer working is Carousel 2.
• Downloaded the file at HTTPS CDN Helper - ActionsForge.
• Double cliked the file and installed to Freeway as per the on screen promps.
• Applied the action to every page of the sit sine since every page ahs Carousel 2 appiled to it.
The Carousel are still stationary though.
It’s hard to say. The source in your site appears to be unchanged. Try making a new document in Freeway, close your existing one for good measure, and try applying the Carousel2 Action and HTTPS CDN Helper to one page. You’ll have to make a few elements on the page and apply the Carousel Action to them, so it will add its code to the page. Publish that, and post a link, or just view source in your browser and see if the script src tags in the head begin with http or https.
Also, after you applied the Action to your page, did you also check the “Secure” checkbox?
On Sep 21, 2017, at 5:18 PM, Tony email@hidden wrote:
Hi Walter
Have I applied the action correctly?
