There are no limits except total page size (megabytes). I recommend creating the first pane, then using Item / Duplicate to create the second, third, fourth, etc. After you make your first pane (in the place where you want the whole effect to appear on screen) and you have a duplicate of it in some other spot (usually in the pasteboard above the page) you can apply the Carousel 2 Action to the first, and Carousel 2 Pane Action to the second. Once you have those two done and dusted, you can duplicate the second one with all settings preserved and simply update the photos or other content in the duplicate panes.
If you have a page where the panes aren’t all appearing on line somewhere, post a link so we can check it out in a JavaScript debugger.
On May 25, 2014, at 2:53 PM, Bob Gordon wrote:
I’m using Carousel 2 in FwyPro 6. Basically have things working.
Issues:
Is there a limit on the number of pictures (Panes)?
I’ve been copying/pasting from one page to the next and then dragging the pictures into the panes. This seems to work, but is it ok?
The reason I ask is that on the last page I did, not all of the pictures appear.
