I’ve implemented a carousel action with “previous” and “next” buttons which works absolutely fine, but have a few questions:
When automatically gliding, the carousel does not stop when either “previous” or “next” are clicked. Is there any way to make this happen?
Is it possible to create buttons that “pause” and “play” the carousel when in auto mode? If so, what would be the code for this?
Ideally I want a carousel that plays by default but also has all 4 controls: “Play, Pause, Previous, Next”. Can this be achieved with the Carousel action or indeed in any other way within Freeway? Are there any other actions / plugins that would work (excluding Flash ones).
This was pretty easy to add, so download the latest from ActionsForge.
I changed the Button control slightly, so instead of only allowing
previous and next, it also allows you to choose Start and Stop Auto-
glide. In addition, Previous and Next controls will also stop the auto-
glide if it’s already running.
On Mar 28, 2011, at 8:03 PM, Halcro wrote:
Hey,
this happen?
ones).
