Is it possible to have a carousel slide by a single increment ?
For example Carousel 500px wide contains 5 images 100px wide and the Carousel Pane contains 4 images. Can the Carousel step forward and back by a 100px increments?
Not the way it is written. You could certainly move in 100px
increments if your carousel element was 100px wide, but there’s no way
to have multiple elements showing and still only move by one element’s
width at a time. It’s kind of a one-trick pony in this regard.
On May 3, 2011, at 10:42 AM, Ger wrote:
Hi,
Not the way it’s currently written. The functionality is there in
Lightwindow.js, the open-source JavaScript library that powers the
effect, but it is stripped out in the Action method because there’s no
good way to build such a gallery in Freeway given the limitations of
the Freeway 4 interface (my baseline for this Action). You might want
to try using the Showcase application + Action bundled with Freeway
5.5, as that does build a navigable folder gallery.
On May 3, 2011, at 11:15 AM, Ger wrote:
Hi Walter,
Thanks for the quick reply. Looks like it’s back to the drawing
board on this one.
Just one other thing is it possible to add previous/next navigation
to Scripty Lightbox?
