Would it be possible to add a fade option to the Carousel action in addition to the horizontal and vertical options? I would like to have the Carousel Panes fade in and out instead of sliding horizontally or vertically.
Walter, I’m guessing you’re the only one to answer this one.
Thanks, Warner
