The Carousel on the pages example above has stoped working. How do I fix this?
The issue is being caused by external scripts coded into the website trying to load over http rather than https, meaning that it won’t load correctly as your site is secure.
An example of this from Chrome’s browser logs show:
This will be because in your website code, it’s set specifically to http rather than https - this would need to be updated on the side the website is built then the new versions uploaded.
There’s two ways to solve this. First, if you’re using Carousel2, there is an update available on ActionsForge that will send all the scripts via https. Universally, there’s another Action you can add to the same page as Carousel (any version) and fix this. https://actionsforge.com/actions/https-cdn-helper
On Mar 22, 2021, at 9:16 AM, Tony email@hidden wrote:
Hello All
