Hello Walter and all
I just made a new carousel and I never came across a problem like this. I mage all html and graphic layers , imported files , ticked Carousel and the rest as C Panes… great & buttons and named everything from item to a real name It works fine. The 2 images that are not vertical and horizontal, do not come up full frame and cut off. I even created the file the same size, so that was not the problem… I wonder if any of you can take a look to see what I am not doing right. I continue to trouble shoot but to no avail
Thanks so much here is link
http://exitcuckoo.com/exitcuckoophotos.html
