Hi, I have used the Carousel2 action which works well. The only issues is that on certain pages, the 4 carousel images are still visible in the margin. (See my sample link) In Firefox in particular, the sometimes flash on during the page load and then dissapear. Question is, must the carousel images be stored in the margin on the pasteboard or stacked on top of each other below the main carousel image.
I always place my carousel 2 panes in the pasteboard area, usually above the page area, but i do not think it matters. if i need to reorder the sequence of the Carousel 2 panes i switch to Page view in the left hand pane, and move (back or Forward) their position there.
Thanks Dave, seems that the action was applied incorrectly on a few pages, I just selected a working example from another page, pasted it into position and dropped the correct images in. Seemed to do the trick.
You can place your panes anywhere on the page or pasteboard that you want. When you see these images in plain sight, it means that you have a JavaScript error in the page for some reason. Glad that copy and paste cleared that up.
