The usual cause of this problem is your page not having the JavaScript
libraries properly linked. Try holding down the Control key, and
choosing Publish Everything from the File menu. (This hidden option
appears when you have Control held down while you choose from the main
menu.) What this might do is jolt Freeway into publishing and properly
linking those files to your page. Also download the very latest
version of the Action from ActionsForge, as there were a few changes
to be compatible with 5.5 if that’s what you’re using.
On Oct 29, 2010, at 9:06 PM, sampolfonz wrote:
Greetings.
I was building a carousel today, just like I have for about a year
now, although this is the first time I have built one using Freeway
5.5.
Today carousel will change, but it will not “glide” like the
carousels I have previously built.
The tabs direct the carousel to the correct pane, however now they
will not glide gracefully…they just jump, as if selecting to a
linked page.
