I’ve had a tour through the code, and I can’t see a way to do this. I have been able to get close to this on another system (Control.Tabs from LivePipe, but I wasn’t ever able to get it to ignore the anchor behavior (what naturally happens if you create a link to an item including a hash) where the page scrolls down to the top of the element in the link. What I ended up doing in that system was making my links with a search:
…that will link you to the CCC tab of the home page, overriding your cookie from previous visits and everything. That code had to be hacked directly into the Control.Tabs source, I will have to look again at Glider.js to see if there’s a spot where I could insert this trickery.
