Any idea why the carousel on my “product pages” (for example: www.newwheel.net/store/OHM-Urban-XU700/) are not sliding correctly in Google Chrome? Everything works great in Firefox and Safari, but not in chrome.
Any help greatly appreciated.
For starters, you have a bunch of validation errors in that page. (It looks really nice, but it doesn’t pass muster with the W3C.) Your FeedBurner tag is using XHTML syntax but your page is in HTML Transitional format, there’s a duplicate ID, a few other errors that probably spill out of that FeedBurner issue…
I suspect that if you fix those then Chrome will be fine. But if not, then try getting rid of all other JavaScript on the same page. I don’t think this is a problem in Carousel per se.
