I have designed a web page a with a carousel, that also has tabs and next/prev buttons.
On this page I have also placed ‘anchors’ at the bottom to take you back to the top and main (gallery) on the page, however these anchors used the smooth scroller script below by Dezinerfolio.
I paste in this HTML markup In the before head section as follows, but when I click on the carousel buttons they cause the page to scroll down to the anchors at the bottom of the page? Does this use a different Library that is not compatible with the ‘carousel’ action?
* Smooth Scroller Script, version 1.0.1
* (c) 2007 Dezinerfolio Inc. <email@hidden>
* For details, please check the website : http://dezinerfolio.com/
Scroller = {
// control the speed of the scroller.
// dont change it here directly, please use Scroller.speed=50;
speed:10,
// returns the Y position of the div
gy: function (d) {
gy = d.offsetTop
if (d.offsetParent) while (d = d.offsetParent) gy += d.offsetTop
return gy
// returns the current scroll position
scrollTop: function (){
body=document.body
d=document.documentElement
if (body && body.scrollTop) return body.scrollTop
if (d && d.scrollTop) return d.scrollTop
if (window.pageYOffset) return window.pageYOffset
return 0
// attach an event for an element
// (element, type, function)
add: function(event, body, d) {
if (event.addEventListener) return event.addEventListener(body, d,false)
if (event.attachEvent) return event.attachEvent('on'+body, d)
// kill an event of an element
end: function(e){
if (window.event) {
window.event.cancelBubble = true
window.event.returnValue = false
return;
if (e.preventDefault && e.stopPropagation) {
e.preventDefault()
e.stopPropagation()
// move the scroll bar to the particular div.
scroll: function(d){
i = window.innerHeight || document.documentElement.clientHeight;
h=document.body.scrollHeight;
a = Scroller.scrollTop()
if(d>a)
if(h-d>i)
a+=Math.ceil((d-a)/Scroller.speed)
else
a+=Math.ceil((d-a-(h-d))/Scroller.speed)
else
a = a+(d-a)/Scroller.speed;
window.scrollTo(0,a)
if(a==d || Scroller.offsetTop==a)clearInterval(Scroller.interval)
Scroller.offsetTop=a
// initializer that adds the renderer to the onload function of the window
init: function(){
Scroller.add(window,'load', Scroller.render)
// this method extracts all the anchors and validates then as # and attaches the events.
render: function(){
a = document.getElementsByTagName('a');
Scroller.end(this);
window.onscroll
for (i=0;i<a.length;i++) {
l = a[i];
if(l.href && l.href.indexOf('#') != -1 && ((l.pathname==location.pathname) || ('/'+l.pathname==location.pathname)) ){
Scroller.add(l,'click',Scroller.end)
l.onclick = function(){
Scroller.end(this);
l=this.hash.substr(1);
if(a[i].name == l){
clearInterval(Scroller.interval);
Scroller.interval=setInterval('Scroller.scroll('+Scroller.gy(a[i])+')',10);
// invoke the initializer of the scroller
Scroller.init();
* END OF CODE
</script>
I have also tried applying protaculious to the page, select scriptacilious-packed library and in the function body paste:
$$('a').each(function(elm){
if(elm.href && $(elm.href.split(/#/).last())){
elm.observe('click',function(evt){
evt.stop();
Effect.ScrollTo(elm.href.split(/#/).last());
This also has the same effect? I was wondering what the issue is, or if I have a bug?
The only work around atm is to remove the carousel buttons!
Any ideas guys would be great!
Worm
