Protaculous can be used to add libraries to the page, and/or to add multiple bits of JavaScript code that rely on those libraries.
Carousel is built into the Protaculous Action “bundle”, and it does a number of specialized effects using the Prototype and Scriptaculous libraries. Net result: if you have a Carousel on the page, then you already have Prototype and Scriptaculous/Effects in your page.
If you need other Scriptaculous libraries (Drag/Drop, Builder, Slider, and Controls) then you can ALSO apply Protaculous to the same page and choose Scriptaculous-packed from the Library picker. This will load them all. The Scripty Actions (which also includes the Freeway FX Actions bundled in Freeway 5+) all cooperate at publish time to ensure that all required libraries are loaded. All of the FX and my various special-purpose Scripty Actions load the “packed” versions of the libraries, but that shouldn’t matter much as they also check to see if the non-packed developer versions are loaded, and use those if they exist.
On Oct 16, 2012, at 5:47 AM, rakeljuice wrote:
Hello, Max. Thanks for your answer.
At the gallery page, I have added the Protacolous action, and deleted the carousel. Then, the gallery works with lightbox, but I cant have a carousel in this page. Isn’t it?
Another thing: you say “where you have added a WebYep light box item”. But in my action, there is no a gallery lightbox item. There is a gallery item, and the lightbox, I put it in the opt folder at webyep system. Is it ok?
Thanks again.
