I am running Freeway 5.5 Pro/ on iMac 10.7.2.
I have been attempting to use the Carousel slide show but wish to have it without the smaller panes to choose from. I would also like it to be smaller than it has made it.
In desperation. I then tried to use the sequence timer. Followed the on-line tutorial exactly but the photos I downloaded one by one, did not appear.
I will appreciate any help!!!
Tobé
Can you post a link please Tobé - not sure what you mean about not having the smaller panes.
Here is the page - http://www.tobesite.com
I would like the top photo to be smaller and to eliminate the bottom run of thumb sized photos.
I am only seeing the ETB ground anchors form at that address Tobé
Sorry! I am having a horrid time with uploading the new page. It looks as though it loads but when I go to the internet it is not there. The older page was put up a number of years ago. I have been talking with goDaddy. Have all the right passwords etc.
Could you help with my other question while I work on the uploading problem: Why I am unable to properly create a slide show. I follow Freeway’s tutorial step by step. The first photo and duplicate are created. The other photos do not load on the page. And nothing shows up on-liine.
Remember, I am running LION, iMac 10.7.2.
Tobé
If I could see your example I would have a better idea why you are going wrong.
You can make the Carousel panes any size you like and you do not need to have the thumbnails beneath.
Which Tutorial is that?
Here is the tutorial I used to make the slide show: http://www.softpress.com/support/tutorials/HQ/11/
The photos do not download onto the page.
I finally got that to work. BUT now when I try to also put a pop-up on the page, it will not take. Do I need the slide show to work only by clicking in order to have more than one special effects item on a page? It worked on my older site: Websitesbytobe.com
What sort of Pop Up are you trying to use?
I am using Pic to New Window. What is happening now is that, although I set up each one correctly, they all pop up with the last photo I entered. There are three pop-ups.
I moved my domain names to goDaddy yesterday. It will take a few days before I can upload so that you can see everything.
Just your domain name management or your hosting too?
If your hosting then I hope you will not regret it…
There is no reason why pic in new window shouldn’t work with Carousel but I think you would get a nicer effect with ScriptyLightbox
The black box in the first carousel pane has a ScriptyLightbox link on it. http://www.deltadesign.co/fw_examples/minicarousel.html
