On 11 Nov 2011, 11:23 am, nick Jest wrote:
Please can anyone help?
I am quite new to freeway and trying to use carousel for the first time having just downloaded.
I am working from the insruction sheet provided, but seem to be having problems.
Having drawn a html box, I’ve been asked to enter inline content prior to calling in images.
Could any one explain to me what this means.
Also at a later point having called in my 4 images into 4 html boxes it asks that I choose the desired ‘parent’ carousel using the picker in the actions pallette.
I hav ebeen through this a number of times and seem to be stuck, can someone help me!!!
Many thanks
Nick Jest
On 11 Nov 2011, 12:19 pm, tonzodehoo wrote:
It just means making your graphic boxes children of the html box you have created. They should be nested inside the html box.
You can see this in the side site panel when an item is indented beneath another.
On 11 Nov 2011, 12:41 pm, tonzodehoo wrote:
Hi thanks for that info, but still got problems.
Once I have produced the first html box and put the graphic box in as a child, I then duped both html and graphic boxes four times as I need four panel in total sliding in and out. When it comes to selecting each panel in turn do I select both html and graphic box then apply the action. I have tried this but keeep getting java script error.
I know I,m doing something wrong but confused as to what.
Many thanks and any advice would be great
Nick Jest
