I am trying to use the Caxton Action together with WebYep, but WebYep seems to disable the Caxton fonts.
Any suggestions?
HELP!
actionsdev mailing list
Any suggestions?
HELP!
Hi… Caxton and webyep work fine together… here is an in progress site example of caxton font and a webyep menu
http://www.sophieyershonphotography.co.uk/gallery.php?DOC_INST=5
From the test i have done it works flawlessly
I would need to see how you have constructed the freeway document to see the problem so if you can send an example of it over to me I will have a look
speak soon max
Hi Max, I also have a question on this subject: Caxton uses a Freeway action combined with the kit downloaded from FontSquirel and the font and style is selected from the Freeway menu, but WebYep uses browser editors “TinyMCE” or “RTE” and the font and style is selected using the browser editor. How do I use both?
Marcus
Eureka! I found the way, Max. Using the TinyMCE and Edit CSS Style I entered the font name I downloaded from FontSquirrel and it worked! Thanks anyway, Max
Marcus
