Hi,
both fonts appear to be displaying for me - and neither are installed on my system. I was able to check that Helvetica was not being displayed (instead of Dejavu sans) by disabling the font using Safari’s Inspector.
There may be a number of things playing against you - caches being the most obvious. These will be local to your browser, and depending on how keen your ISP is, cached with them too.
Thanks for that Paul, it may be that I’ve chosen a font that at such a small size, is too similar to helvetica to be able to tell the difference, so maybe it’s been displaying correctly all the time!
Are you able to cast any light on why the leading is so tight or, again, does that look okay to you?
